Mid drive i "Gear box" all in one...
m2
Postovi: 1453
Post Postao/la m2 »
Zadnja izmjena: m2, dana/u 05 srp 2020, 08:35, ukupno mijenjano 15 puta.
Prazno?
m2
Postovi: 1453
Post Postao/la m2 »
Continental
https://continental-bicycle-systems.com ... Revolution
https://www.youtube.com/watch?v=ppalp1jL3qQ
....48V Revolution
With the 48V Revolution, our system encompasses a world-first innovation. Through the 2-in-1 integration of 48V eBike mid-motor and stepless planetary gear, Continental presents the first-ever fully automatic and stepless eBike drive....
Mubea
https://youtu.be/el7Yk3axtSw
m2
Postovi: 1453
Post Postao/la m2 »
Kervelo Quartz drive for ebike
https://www.youtube.com/watch?v=BmTQ4w3ub0U
Ako je itko zainteresiran ,nudimo :
https://www.maserati-ebikes.com/
6000 eur, keš
Motor i baterija su Fazua.
https://cyclingindustry.news/maserati-r ... man-award/
m2
Postovi: 1453
Post Postao/la m2 »
Continental odustaje od epogona sa integriranim mjenjačem
https://www.youtube.com/watch?v=JSP8X8x0hJQ
m2
Postovi: 1453
Post Postao/la m2 »
Revonte...
m2
Postovi: 1453
Post Postao/la m2 »
m2
Postovi: 1453
Post Postao/la m2 »
<iframe width="1280" height="720" src="https://www.youtube.com/embed/VsZQn2F4POU" title="Revonte ONE transmission explained" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture"></iframe>
m2
Postovi: 1453
Post Postao/la m2 »
<iframe width="1255" height="706" src="https://www.youtube.com/embed/-MBaP4PZpKY" title="Pinion drop massive bombshell - Integrated EMTB Gearbox & Motor" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share"></iframe>
m2 je napisao/la:Pinion
Zanimljiv koncept i super fora sa micanjem mase mjenjaca sa zadnjeg kotaca.
m2
Postovi: 1453
Post Postao/la m2 »
Mid drive +regen
Automatic Digital Transmission System (ADTS®)
Infinitively variable ratio is done digitally. No mechanical gears shifting. Seamlessly, virtually and continuously the system modifies the ratio to set the perfect configuration for the rider (depending on speed, slope, selected map…).
https://newatlas.com/bicycles/niche-aut ... ticle-body
https://niche-mobility.com
Sad i ovi koje hoće pedalirati i puniti bateriju su došli na svoje :)
Polako se gubi smisao bicikla kao jeftinog i za održavanje jednostavnog prijevoznog sredstva.
Ćemu bicikli skuplji od auta koji zahtijevaju promjenu ulja u ovlaštenom servisu ?
m2
Postovi: 1453
Post Postao/la m2 »
debeli je napisao/la:Polako se gubi smisao bicikla kao jeftinog i za održavanje jednostavnog prijevoznog sredstva.
Nije li tako sa svime što se masovno proizvodi?
Često puta da se popravak ne isplati => baci i kupi novo... :x
Ležaj stroja za pranje rublja - promjena skoro 30% vrijednosti novog jer je ležaj dio bubnja (mjenjaš cijeli bubanj u mom slučaju...) :oci:
Mislim da je došlo vrijeme da se napišu zakoni o principima po kojima se novi proizvodi trebaju proizvoditi.
Npr da većinu kvarova korisnik može otkloniti kod kuće sa osnovnim alatom za manje od 60 minuta.
Da pogonski motor mora izdržati barem 20 godina..
Itd,itd.
Tek kada državljani shvate da su političari samo sluge i da su krivično odgovorni ako ne djeluju u skladu sa najvišim interesima državljana, moći ćemo se baviti tehnikalijama .
Ne vidim nikakvu dobrobit za društvo od skupog bicikla. Jedino vlasnik firme tu ima neku korist.
