Wakeboard
Wakeboard
<iframe width="560" height="315" src="https://www.youtube.com/embed/82gFzJl4_k0?rel=0" frameborder="0"></iframe>
Wakeboarding sure looks like a lot of fun, but it does have at least one limiting factor – you need to find someone else to go out on the water with you, to pilot the boat. Swedish entrepreneurs Alexander Lind and Philip Werner decided to do something about that, and created the Radinn electric wakeboard. While it doesn't provide you with a wake on which to do tricks, it does let you go out when and wherever you want.
Currently in working prototype form, the Radinn has a carbon fiber body, a salt water-resistant jet propulsion system, and is powered by a lithium battery pack. That pack sits in a watertight compartment, and it can be removed for easy charging – this also means that if users get an extra battery, they can swap it in as soon as the first one gets low. The whole board, including battery, weighs about 29 kg (64 lb).
Speed is controlled by a wireless waterproof handheld remote. The board currently can travel at up to 25 knots (29 mph or 46 km/h), although the final commercial version will likely be able to go faster. One charge of the battery should reportedly be good for 45 to 60 minutes of use at mixed speeds, or 20 to 30 when going full-out.
