LED rasvjeta
LED i ostala štedna rasvjeta
Postovi: 13236
LED rasvjeta
First Supermarket with 100% LED Lighting
The Migros Supermarket in Eschenbach, Switzerland, sets an LED milestone by switching to 100% LED lighting throughout the entire store--in the refrigerated compartments, overhead, and accenting the selection of products on offer. This project demonstrates once again the ecological superiority of the LED technology. Migros expects to sink energy use 80%, including lower air conditioning costs due to the low waste heat generation of light emitting diodes. "How many Migros technicians does it take to change a light bulb?" None for the next 16 years! That's 50,000 hours of light, compared to 1,000 hours for an old-fashioned filament lightbulb. In addition to the waste reduction achieved by this long life-span, LEDs do not use harmful mercury nor lead. And there is one last, perhaps less obvious, advantage to LED lighting in a supermarket: LEDs emit no ultraviolet nor infrared light, minimizing spoilage of foodstuffs. According to the Osram case study: "Among light experts worldwide, the project is regarded as being unique, and blazes the trail into the LED future."
VladoK
Postovi: 2034
Re: LED rasvjeta
Post Postao/la VladoK »
Napokon :D jedna prava tema ;) predložena od e-vozila.
LED dnevna svjetla. To je to što me sada sve više zanima.
Gdje i pod kakvim uvjetima nabaviti 2 LED lampe 12V za dnevna svjetla na automobilu? :P
Postovi: 13236
Re: LED rasvjeta
VladoK je napisao/la:Napokon :D jedna prava tema ;) predložena od e-vozila.
:o :prigovara: :revolveras:
windman
Pridružen/a: 01 stu 2006, 11:23
Lokacija: tamo negdje
Post Postao/la windman »
ja sm cuo da imas u metrou ili pevecu 12v male neonke
Oldtimer
Postovi: 648
Pridružen/a: 28 sij 2007, 21:39
Lokacija: na cetiri rijeke
Post Postao/la Oldtimer »
windman je napisao/la:ja sm cuo da imas u metrou ili pevecu 12v male neonke
:smijeh1: :smijeh1: Vlado navali :smijeh2: :smijeh2:
___________________
Sto se Agloca tice, procitaj ovdje, cini se da je to jos jedna glupost
za navlacenje naivnih :
http://www.tradersnarrative.com/what-ev ... o-744.html
VladoK
Postovi: 2034
Re: LED rasvjeta
e-vozila je napisao/la:
Hu, jebote još budem poginul bez zrna baruta u pol bijeloga dana slika no dobro, dobro prijatelju e-vozila, pa nije to tako loše, tema je za mene strašno zanimljiva,
jedino ju Windman nije razumio :smijeh2: Windman ti si car s neonkama umjesto LED ica slika
windman
sto ste odmah navalili? :? pa ja sam samo dao prijedlog gdje mislim da imas neonki na 12V, ledice na 12V nisam vidio. nisam mislio da ces stavit prednja i zadnja svijetla neonke, nego onako da stavis pod motor ili ispod volana za sminku
Nixa
Postovi: 1116
Lokacija: Crazy Hill
Post Postao/la Nixa »
windman je napisao/la:sto ste odmah navalili? :? pa ja sam samo dao prijedlog gdje mislim da imas neonki na 12V, ledice na 12V nisam vidio. nisam mislio da ces stavit prednja i zadnja svijetla neonke, nego onako da stavis pod motor ili ispod volana za sminku
Vredu su neonke za šminku. Al post je ipak o rasvjeti ledicama, a ne šminki.
Kao 1. - Neonke ne rade na 12 volti vec na par kilovolti. Računaj kolki napon treba da probije neonku od kakvih 30 centimetri! (Lupam na pamet :roll: , al sigurno je više od 4-5 kV.)
Kao 2. - Te neonke rade na izmjenični napon od nekoliko kHz.
Sad ledice.
Rade na istosmjerni napon. Uzmi za primjer one jeftine kaj ih stavljaju u upaljače. Jedna radi na 4.5V. Da bi ih mogao spojit na 12-14V koji ti se javljaju u autu npr, spojiš ih 3 u seriju i nemaš brige da bu koja zgorela.
Tak ja imam osvjetljenje čukica v jugari.
Jednostavno pogledaš na kojem naponu LED-ica radi, podijeliš postoječi napon na koj ih misliš spojit sa radnim naponom LED-ice i dobiš cifru kolko ih se spaja u seriju.
Npr. 14V(u autu)/4.5V(radni napon LED-ice) =3,1111111111111111111111111111111 iliti ga kad zaokružiš ispadne 3.
A ak očeš naprimjer stavit jednu LED-icu na 12V, jednostavno joj dodaš otpornik od cca 1 - 1.5 kOhm... (opet lupam na pamet! :roll: )
windman
znam da neonke rade na vise kilovolti. samo ova neonka ima elektronik koja dize napon.valjda si vidio kada stavlljas neonke imas kutijicu u kojoj je elektronika.
Nixa
Postovi: 1116
windman je napisao/la:znam da neonke rade na vise kilovolti. samo ova neonka ima elektronik koja dize napon.valjda si vidio kada stavlljas neonke imas kutijicu u kojoj je elektronika.
Al zato za ledice netrebaš nikakvu elektroniku. Samo drmaš seriju! ;)
VladoK
Postovi: 2034
Da ne bude zabluda. Ovako izgledaju žarulje od LED-ica za ugradnju u lampe za dnevna svjetla na vozilima.
Postovi: 13236
Prije 1-2g. smo se ozbiljno napalili da uvozimo i prodajemo LEDice i LED sklopove
Izmedju ostalog i ove za aute
Mozda jednom i krenemo u to :P
VladoK
Postovi: 2034
e-vozila je napisao/la:Prije 1-2g. smo se ozbiljno napalili
Napalili i... zgoreli :(
Nixa
Postovi: 1116
Jel bi ledice imale dovoljno svjetla za nočno osvjetljenje vozila, kao na primjer mojeg Harleyja? I opet, kolko bi to bilo dobro za nočno osvjetljenje pošto ledice emitiraju jednovalno svjetlo?
Imam jednu baterijicu na ključevima kao privjesak koja koristi bijelu ledicu. Dobro se vidi kad se nešto osvjetli, al baš i nije ugodno za duže gledanje jer je sve što se osvjetli neke nijanse sive boje. Čak vuče malo na plavkasto...
Postovi: 13236
VladoK je napisao/la:Napalili i... zgoreli :(
Nemozemo sve odjednom..znas onu pricu s misem ;)
Natrag na “LED rasvjeta”
