Front Electric Sustainer
- Luka Znidarsic
- Postovi: 14
- Pridružen/a: 03 srp 2009, 00:32
- Lokacija: Slovenia, Logatec
- HAL9000v2.0
- Postovi: 1810
- Pridružen/a: 09 svi 2007, 21:46
- Lokacija: Zagreb
- Kontakt:
- Luka Znidarsic
- Postovi: 14
- Postovi: 673
- Pridružen/a: 06 lip 2009, 09:48
Ne citasmarkostrujic je napisao/la:bok luka
mrak letjelica
koju vrstu lifepo4 baterije koristite , pretpostavljam da nije takoder "domaca proizvodnja":)?
The drive battery of the FES consists of 20 lithium ion polymer cells. The battery operates at a voltage range of 60 to 85 Volt. There is 3,6kWh of energy available in two battery boxes. Each of them weight 11kg. They are located in reinforced fuselage area behind the wings. Batteries fully compensate weight of motor and propeller in front.
- Postovi: 673
- Postovi: 673
- Luka Znidarsic
- Postovi: 14
Motor za FES je konstrukcijsko prilagojen spinerju itd. Če potrebujete motor vam ga lahko izdelamo po naročilu, prirejenega za vašo aplikacijo!
LP
Luka Žnidaršič
www.front-electric-sustainer.com
LP
Luka Žnidaršič
- Luka Znidarsic
- Postovi: 14
Če potrebujete dober motor imam enega na zalogi:
Mišljen je bil za FES, vendar mi vpetje ni ustrezalo!
http://e-vozila.com/forum/viewtopic.php?p=28961#28961
LP
Luka
LP
Luka
pa i to piše:markostrujic je napisao/la:OKEJ EV -got the point ,novo pitanje : KOJE LITHIUM ION POLYMER BATERIJE SU U AVIJUNUUUU
The drive battery of the FES consists of 20 lithium ion polymer cells pruduced by Kokam. We use high power cells with capacity of 45 Ah. Cells are wired in serial and operates at a voltage range of 60 to 85 volts.
