e-Kona
DarioV
Pridružen/a: 06. 04. 2016.
Postovi: 93
PostPostano: 14.5.2016. sub. 22:54    Naslov: e-Kona Citirajte i odgovorite
Pozdrav svima na forumu.
Odlucio sam se na slaganje elektricnog bicikla, inace dosta dugo vozim, slazem i odrzavam svoje bicikle, ali sam skroz nov u ovima na struju, u zadnje vrijeme sam dosta proucavao po netu, ali ce mi sigurno dobro doci svaki savjet.
Pacijent je Kona Pahoehoe Smile
RAMA: ...............................Kona Pahoehoe 2002
VILICA: ..............................Manitue R7 Super TPC
LEŽAJ VILICE:.......................FSA Orbit MX
POGON: .............................Shimano XTR FC-M970
LANČANICI POGONA...............Shimano XTR (22/32/44)
LEŽAJ POGONA:....................Token TK-877EX
LANAC:.............................. KMC X9 Gold
KAZETA:............................. Shimano XTR CS-M970 11-34T
MJENJAČ PREDNJI:................ Shimano XTR FD-M970
MJENJAČ STRAŽNJI:............... Shimano XT RD-M771
RUČICE MJENJAČA:................ Shimano RapidFire/Tuned
SAJLE/BUŽIRI MJENJAČA..........Aligator/Jagwire
KOČNICE:............................ Magura Marta Carbon
ROTORI:..............................Avid HS1 160/160mm
PEDALE:..............................Contec Rapid
VOLAN:...............................Easton EC90SL 635mm
LULICA:..............................Thomson Elite X4 100mm
GRIPOVI:.............................Bontrager Race XXX Lite
SJEDALO:.............................Selle Italia X2
CIJEV SJEDALA:......................Kona 27,2mm
ZATEZAČ CIJEVI SJEDALA...........Kona 31,8mm
KOTAČI:..............................Fulcrum RedMetal 3
ZATEZAČI KOTAČA................. Shimano XTR
GUME:............................... Continental X-King
Nesto Artasovih dijelova za struju sam vec nabavio:
Motor crystalyte HT-3525 (H48)
Kontroler N48/H48
Rucica gasa
Crystayte-ov srebrni obruc sam plastificirao u crno i dao isplesti kotac, pa kad bude gotov bacam se u izradu torque arm-a i nekih malih prekidaca u rucicama kocnica za regen, nadam se da ce za kojih mjesec dana pasti i prva e-voznja. Smile
Zadnja promjena: DarioV; 7.12.2016. sri. 01:22; ukupno mijenjano 1 put.
Postovi: 5449
PostPostano: 14.5.2016. sub. 23:24    Naslov: Citirajte i odgovorite
Nije baš sretna kombinacija. Motor je dobar ali da bi prodisao treba jači kontroler, bar 40-50A i bateriju 60-72V.
Ovako će dvostruko skuplji motor davati iste performanse kao i N48 što je stvarno šteta.
PostPostano: 15.5.2016. ned. 08:47    Naslov: Citirajte i odgovorite
Imam i ja konu koja je elektrificirana. Također i viška LiFePo4 10,3Ah bateriju na prodaju
DarioV
Postovi: 93
PostPostano: 15.5.2016. ned. 12:46    Naslov: Citirajte i odgovorite
Jednostavno ponuda hub motora sa prihvatom za disk je kod nas gotovo nikakva, tako da nisam bas mogao puno birati, ali jako sam zadovoljan izborom motora jer koliko sam skuzio ima veliki potencijal, a i dobio sam ga jako povoljno. Wink
Ako bude potrebe lako se kasnije uzme i jaci kontroler.
Hvala na ponudi, ali Artasova baterija mi nazalost ne stane u ramu.
Postovi: 12243
PostPostano: 15.5.2016. ned. 13:49    Naslov: Citirajte i odgovorite
Joj Grrrrrrga Very Happy ne treba svima 4kW
Svojih 80kg vozim sa 48V bat i tim istim motorom i kontrolerom podešenim na 35A
Bicikl leti!! leti2
Perfomanse neće biti iste kao sa N48 motorom.
Biti će 5km/h sporiji ali sa osjetno jačim momentom i regen kočenjem.
DarioV
Postovi: 93
PostPostano: 15.5.2016. ned. 16:46    Naslov: Citirajte i odgovorite
Svojih 80kg vozim sa 48V bat i tim istim motorom i kontrolerom podešenim na 35A, Bicikl leti!!
Pretpostavljam da koristis 26" kotace, koja ti je maksimalna brzina po ravnom ?
Postovi: 5449
PostPostano: 15.5.2016. ned. 17:46    Naslov: Citirajte i odgovorite
ogi je napisao/la:
Bicikl leti!! leti2
Nisam niti rekao da treba svima 4 kW nego sam rekao da je motor neiskorišten sa original 22A/48V kontrolerom.
Pošto sam složio nekoliko bicikala za istu namjenu i vlasnika (tvoj zadnji H48) rekao je ono što sam napisao, da nema neke razlike osim što je sporiji. Svi su podešeni na 35A.
Za običnu, svakodnevnu upotrebu daleko najbolji omjer cijena/performanse ima N48.
Cromotor bi išao još bolje od H48 sa tim kontoroleom što se toga tiče ali bi to svejedno bio nepotrebno potrošen novac Smile
Postovi: 12243
PostPostano: 18.5.2016. sri. 08:27    Naslov: Citirajte i odgovorite
Ima razlike, osjetno bolji start, savladavanje uzbrdica i kočenje
Da, N48 je imao najbolji odnos uloženo/dobiveno
DarioV
Postovi: 93
PostPostano: 21.5.2016. sub. 20:14    Naslov: Citirajte i odgovorite
Slozen kotac i torque arm. Smile
dakic.dubravko
Pridružen/a: 03. 02. 2014.
Postovi: 403
Lokacija: Samobor
PostPostano: 21.5.2016. sub. 21:53    Naslov: Citirajte i odgovorite
Sad samo litij i vozi misko Smile
Alex1
Pridružen/a: 27. 06. 2010.
Postovi: 762
Lokacija: Klanjec
PostPostano: 22.5.2016. ned. 15:14    Naslov: Citirajte i odgovorite
Ako preferiraš asfalt, nadam se da će past i kakve slick gume, ja sam se preporodio....
munjeni
Pridružen/a: 28. 01. 2010.
Postovi: 340
Lokacija: Stenjevec
PostPostano: 22.5.2016. ned. 20:34    Naslov: Citirajte i odgovorite
Ak je suditi po kočnicama i pogonu taj bu bicikl slabo videl asfalta.
To je više XC pila.
selec1
Pridružen/a: 06. 02. 2011.
Postovi: 194
PostPostano: 22.5.2016. ned. 21:06    Naslov: Citirajte i odgovorite
munjeni je napisao/la:
To je više XC pila.
bas sam htel reci, jebena XC pila. steta te dijelove stavljat na ebike Very Happy
DarioV
Postovi: 93
PostPostano: 22.5.2016. ned. 21:56    Naslov: Citirajte i odgovorite
Litij narucen, dok ne stigne taman montiram kontroler, gas i regen.
To je više XC pila.
Da, XC bajk koji sam slozio zeni i klincima da se samnom na sljeme vozikaju, ali se nazalost slabo vozi jer treba vrtiti hebene pedale.
Sad ce im vjerovatno biti interesaniji jer ide sam uz brdo. Smile
Sto se guma tice vidjet cu kako ce se bajk koristiti, pa stavim odgovarajuce gume, vjerovatno ce neki semislick ici gore.
DarioV
Postovi: 93
PostPostano: 27.5.2016. pet. 14:37    Naslov: Citirajte i odgovorite
Baterija polako napreduje. Smile
Stranica 1 / 5.
