Struja iz biomase
-> Ostalo
Postovi: 12283
PostPostano: 18.8.2009. uto. 23:07    Naslov: Struja iz biomase Citirajte i odgovorite
Postovi: 12283
PostPostano: 18.8.2009. uto. 23:34    Naslov: Citirajte i odgovorite
http://www.tegpower.com
nikola
Pridružen/a: 29. 12. 2008.
Postovi: 311
PostPostano: 19.8.2009. sri. 08:13    Naslov: Citirajte i odgovorite
TEG kužim...mislim da bi se to čak dalo napravit u kućnoj radinosti..hehe... Very Happy
Ali ovo sa biomasom ne...kako to radi??Na koji princip? Confused
Još nešto u vezi sa TEG-om:
http://www.arrickrobotics.com/robomenu/generator.html
Kako kupiti:
http://www.electronickits.com/kit/complete/peltier/ck501.htm
Pošto Peltier čelija služi za hlađenje ili grijanje,da li ako joj dovedemo hladnoću ili pak toplinu ona može proizvodit struju?..za hladnoću bi proces tekao u obrnutom smjeru...hmmm..
turbo
Pridružen/a: 09. 04. 2008.
Postovi: 717
PostPostano: 19.8.2009. sri. 10:49    Naslov: Citirajte i odgovorite
Imaš peltier u chipoteci,mislim da je oko 90 kn.
http://www.peltier-info.com/
peco
Pridružen/a: 07. 05. 2009.
Postovi: 1175
Lokacija: Os.-Slavonija
PostPostano: 19.8.2009. sri. 11:24    Naslov: Citirajte i odgovorite
Peltier i nije baš nešto!
Peltier elements have very low efficiency. They will consume more power than they transport! Actual peltier elements may consume twice as much energy (in the form of electricity) as they transport (in the form of heat). So, if you are using a peltier element, the heatsink it is used with must be much more powerful than a heatsink used for cooling a heat source without peltier element.
Do not confuse the maximum amount of power a peltier element can transport with the maximum amount of power usage of the peltier element. Some retailers sell "80W peltier element", without stating what this value actually means. This is misleading - what you want is a high transport capability, but a low power consumption.
http://www.heatsink-guide.com/peltier.htm
nikola
Postovi: 311
PostPostano: 19.8.2009. sri. 15:19    Naslov: Citirajte i odgovorite
Taj Peltier je u biti PN spoj..nešto slično kao dioda...
Ako je toliko neučinkovito..zašto se uopće koristi?? Confused
http://www.youtube.com/watch?v=2rc0cRTxb0Q&feature=related
još nešto zanimljivo:
http://www.youtube.com/watch?v=CWf9nYbm3ac&feature=related
Postovi: 12283
PostPostano: 19.8.2009. sri. 17:31    Naslov: Citirajte i odgovorite
Uzmimo centralno grijanje na drva
Dolje je pec na drva, u sredini Peltier i na vrhu spremnik sa vodom
Topla voda ide gore i konstantno hladi Peltier
Znaci sva toplinska energija se prebacuje preko Peltiera u spremnik tople vode
Eto topline i struje za zimu Smile
idea
nikola
Postovi: 311
PostPostano: 20.8.2009. čet. 09:02    Naslov: Citirajte i odgovorite
Da..hehe.. 2 u 1 Very Happy
Ček..a zar nije poanta Peltiera da ako zagriješ jedno stranu,druga je hladna??
http://upload.wikimedia.org/wikipedia/en/1/1f/Peltier_(detail)_LMB.png
Postovi: 12283
PostPostano: 20.8.2009. čet. 11:46    Naslov: Citirajte i odgovorite
Da ako odlucis trositi struju
Sto kazete na ovu ideju gore?
Neznam do koliko stupnjeva mogu izdrzati?? Confused
Postovi: 4291
PostPostano: 20.8.2009. čet. 20:00    Naslov: Citirajte i odgovorite
EV je napisao/la:
U principu, do najmanje do 125st.C.
Postovi: 12283
PostPostano: 20.8.2009. čet. 20:54    Naslov: Citirajte i odgovorite
Samo, pa to ce pec rastopit Confused ..osim ako.....
Drago-Zg
Pridružen/a: 10. 01. 2007.
Postovi: 956
PostPostano: 28.9.2009. pon. 19:02    Naslov: Citirajte i odgovorite
Dosta zanimljivo !
http://www.youtube.com/watch?v=BLst-kslKio
m2
Pridružen/a: 11. 06. 2008.
Postovi: 1339
PostPostano: 30.9.2009. sri. 13:18    Naslov: Citirajte i odgovorite
Drago-Zg je napisao/la:
Dosta zanimljivo !
Ima tema na forumu o toj makini
http://www.e-vozila.com/forum/viewtopic.php?t=1559
-> Ostalo
